  • 1 Vote(s) - 5 Average
1936 Philco 116PX Electronic Restoration
#35
> I would get some distortion or rattle from the speaker [Image: http://philcoradio.com/phorum/images/smi...con_eh.gif] .
That would be indicative of a loose, torn, or off center cone in terms of a rattle. Distortion could be a number of things. For this check the voltages around the 6A3's, be sure that the grids are at  negative 60v or so. You can check the specs for the tube in the tube manual to determine the correct voltage. Could have a bad cadohm resistor or  driver transformer. Also check the voltages around the 42 tube for starters.
Any thing I should look out for, considering the type of pickup this has and whether this could work without modifying it too much?
My 116X had a phono jack installed before I got it. It disconnects the detector output and connects the alternative input.
RE: 1936 Philco 116PX Electronic Restoration - by Radioroslyn - 10-17-2017, 10:35 AM
The speaker table error?
Philco 70 antenna lead
