Philco Speaker
The model 14uses Philco's class A triode connected push/pull 42 tube w/a 42 driver. This set up is designed to achieve 10w with very low distortion. In the triode configuration the 42's operate at a lower impedance (abt 6K) than in the typical pentode configuration (abt 14K).
Philco Speaker - by Tapsnap - 10-17-2017, 03:59 PM
RE: Philco Speaker - by klondike98 - 10-17-2017, 04:54 PM
RE: Philco Speaker - by Radioroslyn - 10-17-2017, 07:30 PM
RE: Philco Speaker - by Tapsnap - 10-18-2017, 11:31 AM
RE: Philco Speaker - by morzh - 10-18-2017, 04:34 PM
RE: Philco Speaker - by Tapsnap - 10-19-2017, 02:26 PM
The speaker table error?
Philco 70 antenna lead
