  • 1 Vote(s) - 5 Average
1936 Philco 116PX Electronic Restoration
#40
Mine run a bit warm too. If it keep it on for more than several hour the fan comes on. Line here is about 118v haven't used a bucking trans to lower the input voltage. Because of it's current @ 165w would need about 12v 2A transformer.
RE: 1936 Philco 116PX Electronic Restoration - by Radioroslyn - 10-19-2017, 11:01 AM
Users browsing this thread: 17 Guest(s)
The speaker table error?
Philco 70 antenna lead
