Philco 70 and similar ground leakage
(10-22-2017, 09:00 PM)ntsc525 Wrote:  As for the statement of how much current can kill, I will remind you my measurement was to ground, not through my body.
Yes I know that. It'd be stupid otherwise. I just gave you the killing numver vs what you read on your meter which, given the caps values, is impossible.
10nF seems to be a good value; if want to have no tickle at all, about 2nF would still do the job.
Philco 70 and similar ground leakage - by ntsc525 - 10-22-2017, 01:38 PM
RE: Philco 70 and similar ground leakage - by morzh - 10-22-2017, 09:59 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6454 online users. [Complete List]
» 1 Member(s) | 6453 Guest(s)
