The 39-116 project: the beginning
#38
Hello Brenda and sleuth255,
What did you both do as final values for the 16mfd and 30 mfd capacitors in the volume motor control circuits on your radios? I have a 41-616 and am trying to do determine the best voltage values to replace these with.  Furthermore can you just confirm that you used nonpolarized/bipolar capacitors for both of these.
The 39-116 project: the beginning - by BrendaAnnD - 03-20-2015, 05:47 AM
RE: The 39-116 project: the beginning - by morzh - 03-20-2015, 10:39 AM
RE: The 39-116 project: the beginning - by morzh - 03-20-2015, 02:39 PM
RE: The 39-116 project: the beginning - by morzh - 03-28-2015, 11:54 AM
RE: The 39-116 project: the beginning - by morzh - 03-28-2015, 12:43 PM
RE: The 39-116 project: the beginning - by morzh - 03-29-2015, 11:04 AM
RE: The 39-116 project: the beginning - by morzh - 03-29-2015, 11:37 AM
RE: The 39-116 project: the beginning - by morzh - 04-15-2015, 09:39 AM
RE: The 39-116 project: the beginning - by morzh - 04-15-2015, 09:59 AM
RE: The 39-116 project: the beginning - by morzh - 04-16-2015, 05:11 PM
RE: The 39-116 project: the beginning - by murf - 04-19-2015, 05:49 PM
RE: The 39-116 project: the beginning - by 78zenithtv - 10-24-2017, 02:27 PM
RE: The 39-116 project: the beginning - by Edisla - 10-24-2017, 03:55 PM
The speaker table error?
Philco 70 antenna lead
