reduce voltage
Another thing to check is the negative bias going to the 45 tubes. If any of those resistors labeled 57 and 58 are open or increased dramatically it will also cause a large increase of voltage across the caps in the power supply. Resistor 59 in the cathode circuit of the 45 tubes is worth checking too. It could cause higher than normal B+. These resistors balance the loading of the power supply and should be within 20% tolerance.
reduce voltage - by denver - 03-17-2010, 02:12 PM
Re: reduce voltage - by rghines1 - 03-17-2010, 05:41 PM
Re: reduce voltage - by denver - 03-17-2010, 05:50 PM
Re: reduce voltage - by denver - 03-17-2010, 05:54 PM
Re: reduce voltage - by rghines1 - 03-17-2010, 08:09 PM
Re: reduce voltage - by denver - 03-17-2010, 08:22 PM
Re: reduce voltage - by Ron Ramirez - 03-17-2010, 08:37 PM
Re: reduce voltage - by denver - 03-17-2010, 09:39 PM
Re: reduce voltage - by Carl Travis - 03-17-2010, 09:44 PM
Re: reduce voltage - by rghines1 - 03-18-2010, 08:13 AM
Re: reduce voltage - by denver - 03-18-2010, 01:58 PM
Re: reduce voltage - by rghines1 - 03-18-2010, 06:37 PM
Re: reduce voltage - by denver - 03-18-2010, 07:37 PM
Re: reduce voltage - by denver - 03-21-2010, 07:04 PM
Re: reduce voltage - by denver - 04-06-2010, 04:22 PM
Re: reduce voltage - by Ron Ramirez - 04-06-2010, 05:05 PM
Re: reduce voltage - by rghines1 - 04-07-2010, 09:28 AM
Re: reduce voltage - by codefox1 - 04-07-2010, 11:27 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
