41-608 code 122
Replaced all of the tubes. Added a new power cord and finally plugged the unit in today. All I get is a loud humming sound when turned on. Mananged to tune into a couple of AM stations but still humming loudly. Thoughts why?
Also, when the phono is turned on the needle/arm flash and the turntable does not turn. Thoughts here??
Where to begin with the capacitors...
Not too discouraged yet.
41-608 code 122 - by PhilcoDom - 10-19-2017, 01:03 PM
RE: 41-608 code 122 - by klondike98 - 10-29-2017, 09:03 AM
RE: 41-608 code 122 - by OldRestorer - 10-29-2017, 10:25 AM
RE: 41-608 code 122 - by Radioroslyn - 10-29-2017, 01:50 PM
RE: 41-608 code 122 - by PhilcoDom - 11-05-2017, 03:27 PM
RE: 41-608 code 122 - by sam - 11-05-2017, 06:11 PM
RE: 41-608 code 122 - by klondike98 - 11-05-2017, 09:53 PM
RE: 41-608 code 122 - by PhilcoDom - 12-29-2017, 06:55 PM
RE: 41-608 code 122 - by morzh - 12-29-2017, 07:58 PM
RE: 41-608 code 122 - by morzh - 12-29-2017, 08:41 PM
RE: 41-608 code 122 - by PhilcoDom - 12-30-2017, 09:22 PM
RE: 41-608 code 122 - by morzh - 12-30-2017, 09:23 PM
RE: 41-608 code 122 - by PhilcoDom - 12-30-2017, 09:38 PM
RE: 41-608 code 122 - by sam - 12-31-2017, 06:44 PM
RE: 41-608 code 122 - by sleuth255 - 04-14-2018, 09:39 AM
RE: Philco 41-608 - by Radioroslyn - 10-19-2017, 03:46 PM
RE: Philco 41-608 - by klondike98 - 10-19-2017, 03:55 PM
RE: Philco 41-608 - by PhilcoDom - 10-20-2017, 11:11 AM
RE: Philco 41-608 - by PhilcoDom - 10-28-2017, 08:00 PM
RE: Philco 41-608 - by Radioroslyn - 10-28-2017, 08:52 PM
RE: Philco 41-608 - by morzh - 10-28-2017, 09:31 PM
RE: Philco 41-608 - by PhilcoDom - 10-28-2017, 09:40 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4836 online users. [Complete List]
» 1 Member(s) | 4835 Guest(s)
