Philco 40-125
On this philco 40-120 there are 2 moulded mica caps that have a arrow with 3 dots inside it that are (left to right) red,red,orange.on the riders manual (10-28) I see no cap value that compares to this.One of these micas goes from bottom volume terminal to the top terminal on the volume control terminal.The other mica (same red,red,orange) goes to the 7C6 from the bottom volume control terminal.Can someone please tell me the value of these micas and what # on the parts list for the 40-120 that showed this so I can learn something here. Thank you very much. Mike
Philco 40-125 - by Harpone1 - 10-25-2017, 12:44 PM
RE: Philco 40-125 - by klondike98 - 10-25-2017, 07:01 PM
RE: Philco 40-125 - by Radioroslyn - 10-25-2017, 07:57 PM
RE: Philco 40-125 - by Harpone1 - 10-25-2017, 09:54 PM
RE: Philco 40-125 - by Harpone1 - 10-26-2017, 05:51 PM
RE: Philco 40-125 - by klondike98 - 10-26-2017, 09:56 PM
RE: Philco 40-125 - by Harpone1 - 10-29-2017, 07:05 PM
RE: Philco 40-125 - by Ron Ramirez - 10-29-2017, 09:27 PM
Mica cap value - by Harpone1 - 10-29-2017, 08:57 PM
The speaker table error?
Philco 70 antenna lead
