37-630 Aux Audio
My theory is that the radio signal is getting through by the direct connection between the primary of the second IF transformer (37) and the primary of the output transformer (57). Maybe that would explain its low amplitude. Does anyone see this as a possibility?
37-630 Aux Audio - by JohnJarratt - 10-31-2017, 03:04 PM
RE: 37-630 Aux Audio - by JohnJarratt - 11-01-2017, 09:05 AM
RE: 37-630 Aux Audio - by vinzer - 11-01-2017, 10:05 AM
RE: 37-630 Aux Audio - by Radioroslyn - 11-01-2017, 11:03 AM
RE: 37-630 Aux Audio - by JohnJarratt - 11-01-2017, 11:08 AM
RE: 37-630 Aux Audio - by JohnJarratt - 11-01-2017, 06:29 PM
The speaker table error?
Philco 70 antenna lead
