37-630 Aux Audio
You might try grounding the joint of resistors 39 and 41 to see if stops audio from the radio.
37-630 Aux Audio - by JohnJarratt - 10-31-2017, 03:04 PM
RE: 37-630 Aux Audio - by JohnJarratt - 11-01-2017, 09:05 AM
RE: 37-630 Aux Audio - by vinzer - 11-01-2017, 10:05 AM
RE: 37-630 Aux Audio - by Radioroslyn - 11-01-2017, 11:03 AM
RE: 37-630 Aux Audio - by JohnJarratt - 11-01-2017, 11:08 AM
RE: 37-630 Aux Audio - by JohnJarratt - 11-01-2017, 06:29 PM
The speaker table error?
Philco 70 antenna lead
