37-630 Aux Audio
Hi John,
> Does anyone see this as a possibility?
No not so much.
I think what you are experiencing is leakage from the diode section over to high gain triode section. It's a fairly common thing on sets that use a 12AT6 or 12AV6. When you turn the volume all the way down you still the set playing a little
Would try a different 6Q7 and see if that helps. You could lower the value of 41 say to 220k or so but this will lower the volume of the radio a little.
37-630 Aux Audio - by JohnJarratt - 10-31-2017, 03:04 PM
RE: 37-630 Aux Audio - by JohnJarratt - 11-01-2017, 09:05 AM
RE: 37-630 Aux Audio - by vinzer - 11-01-2017, 10:05 AM
RE: 37-630 Aux Audio - by Radioroslyn - 11-01-2017, 11:03 AM
RE: 37-630 Aux Audio - by JohnJarratt - 11-01-2017, 11:08 AM
RE: 37-630 Aux Audio - by JohnJarratt - 11-01-2017, 06:29 PM
The speaker table error?
Philco 70 antenna lead
