New member / Model 60 Restoration On-going
Scottie, welcome. I am sorry I have not participated much here of late. I am in college, and I have a particularly tough semester right now, so I am staying very busy.
New member / Model 60 Restoration On-going - by Guest - 03-10-2010, 03:41 PM
Re: New member / Model 60 Restoration On-going - by Ron Ramirez - 03-23-2010, 08:40 AM
Re: New member / Model 60 Restoration On-going - by Guest - 03-24-2010, 05:39 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
