Lucky day, majestic 1250 find
I did take off the tuning condenser assembly along with the dial assembly. Then I masked off everything else and bead blasted the rust and the chrome came right off. I also blasted the transformer and painted it straight matt black first then masked it off when I sprayed on the wrinkle finish. The wrinkle finish hid the rust pits and I must say looks 100% better, new rubber groments on tuning condenser and this weekend I should be able recap and check for anything that may need attention.
Lucky day, majestic 1250 find - by Fred Taylor - 08-21-2017, 07:32 AM
RE: Lucky day, majestic 1250 find - by Scott D - 08-21-2017, 07:13 PM
RE: Lucky day, majestic 1250 find - by morzh - 10-17-2017, 10:27 AM
RE: Lucky day, majestic 1250 find - by Eliot Ness - 10-17-2017, 11:40 AM
RE: Lucky day, majestic 1250 find - by KCMike - 10-18-2017, 10:28 AM
RE: Lucky day, majestic 1250 find - by PhilcoJohn - 10-19-2017, 07:09 AM
RE: Lucky day, majestic 1250 find - by Joe Rossi - 10-19-2017, 09:41 PM
RE: Lucky day, majestic 1250 find - by Joe Rossi - 10-23-2017, 05:35 PM
RE: Lucky day, majestic 1250 find - by morzh - 11-01-2017, 08:12 AM
RE: Lucky day, majestic 1250 find - by Fred Taylor - 11-02-2017, 07:46 AM
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 3679 online users. [Complete List]
» 1 Member(s) | 3678 Guest(s)
