Hello! 38-12 Dial Question
I used my two index fingers to pull the pointer out. Icon_smile
By the hub of course.
Hello! 38-12 Dial Question - by Shaleradio - 11-03-2017, 08:20 PM
RE: Hello! 38-12 Dial Question - by Ron Ramirez - 11-04-2017, 08:58 AM
RE: Hello! 38-12 Dial Question - by Radioroslyn - 11-04-2017, 02:49 PM
RE: Hello! 38-12 Dial Question - by morzh - 11-04-2017, 07:47 PM
RE: Hello! 38-12 Dial Question - by klondike98 - 11-04-2017, 08:34 PM
RE: Hello! 38-12 Dial Question - by Shaleradio - 11-05-2017, 09:12 PM
RE: Hello! 38-12 Dial Question - by Shaleradio - 11-07-2017, 08:17 PM
RE: Hello! 38-12 Dial Question - by Radioroslyn - 11-07-2017, 08:53 PM
The speaker table error?
Philco 70 antenna lead
