Ever use too much bathroom tissue??
http://www.electronix.com/speaker-replac...13892.html
Have used these before to recone a few pie pan speakers. Unfortunately they have a foam surround but the price is very good. Finding the all paper cones can be a daunting task with usable dimensions. The critical ones are the center hole (a lot of the modern ones have a large hole) and the depth.
RE: Ever use too much bathroom tissue?? - by sam - 11-01-2017, 01:31 PM
RE: Ever use too much bathroom tissue?? - by sam - 11-01-2017, 09:10 PM
RE: Ever use too much bathroom tissue?? - by Radioroslyn - 11-05-2017, 12:08 AM
The speaker table error?
Philco 70 antenna lead
