48-1270 restoration in progress
The phono looked to be in good shape.
Note from site admin: Sorry, but the photos which were attached to this post are no longer available.
48-1270 restoration in progress - by Guest - 03-16-2010, 03:14 PM
Re: 48-1270 restoration in progress - by planigan - 03-21-2010, 01:43 AM
Re: 48-1270 restoration in progress - by rghines1 - 03-21-2010, 03:49 PM
Re: 48-1270 restoration in progress - by planigan - 03-22-2010, 12:23 AM
Re: 48-1270 restoration in progress - by Guest - 03-23-2010, 07:41 PM
Re: 48-1270 restoration in progress - by Guest - 03-23-2010, 07:56 PM
Re: 48-1270 restoration in progress - by Guest - 03-23-2010, 08:20 PM
Re: 48-1270 restoration in progress - by Guest - 03-23-2010, 08:24 PM
Re: 48-1270 restoration in progress - by Guest - 03-23-2010, 08:36 PM
Re: 48-1270 restoration in progress - by Guest - 03-23-2010, 09:18 PM
Re: 48-1270 restoration in progress - by Guest - 03-24-2010, 09:35 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6844 online users. [Complete List]
» 1 Member(s) | 6843 Guest(s)
