Zenith ID...288??
Ok A little more info..
Pictures of bottom..
[Image: https://farm5.staticflickr.com/4462/2434...2cfc_b.jpg]
[Image: https://farm5.staticflickr.com/4513/2434...6911_b.jpg]
Height of cabinet measures 30 Inches Not counting rollers..
Skip
Zenith ID...288?? - by vecher - 11-05-2017, 07:43 PM
RE: Zenith ID...288?? - by vecher - 11-05-2017, 08:35 PM
RE: Zenith ID...288?? - by Radioroslyn - 11-05-2017, 10:31 PM
RE: Zenith ID...288?? - by Fred Taylor - 11-06-2017, 08:32 AM
RE: Zenith ID...288?? - by Eliot Ness - 11-06-2017, 09:20 AM
RE: Zenith ID...288?? - by w4rtc - 11-06-2017, 12:45 PM
RE: Zenith ID...288?? - by Eliot Ness - 11-06-2017, 02:41 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
