1933-34 Philco 89B Restoration
This might be a little after the fact but those cloth covered wire wound resistors don't take kindly to flexing or movement. Typically resistance wise they are very stable and should stay in tolerance. Just don't bend it.
RE: Philco 89 Capacitor Question - by morzh - 05-18-2017, 02:18 PM
RE: Philco 89 Capacitor Question - by Ron Ramirez - 05-18-2017, 03:07 PM
RE: Philco 89 Capacitor Question - by morzh - 05-18-2017, 03:31 PM
RE: 1933-34 Philco 89B Restoration - by morzh - 11-06-2017, 10:13 AM
RE: 1933-34 Philco 89B Restoration - by Radioroslyn - 11-06-2017, 03:30 PM
RE: 1933-34 Philco 89B Restoration - by morzh - 01-16-2018, 02:21 PM
The speaker table error?
Philco 70 antenna lead
