Non-Philco general question
Thank you. I had forgotten that I changed my work light to a CCFL. With the CCFL replaced, no noise.
Just needs a good alignment.
Sorry about placing in the wrong folder.
Don
Non-Philco general question - by 45philcodon - 11-07-2017, 06:39 PM
RE: Non-Philco general question - by morzh - 11-07-2017, 06:44 PM
RE: Non-Philco general question - by klondike98 - 11-07-2017, 07:30 PM
RE: Non-Philco general question - by Radioroslyn - 11-07-2017, 09:34 PM
RE: Non-Philco general question - by 45philcodon - 11-07-2017, 09:51 PM
RE: Non-Philco general question - by morzh - 11-07-2017, 11:34 PM
RE: Non-Philco general question - by Ron Ramirez - 11-08-2017, 07:30 AM
RE: Non-Philco general question - by Radioroslyn - 11-08-2017, 01:17 PM
RE: Non-Philco general question - by morzh - 11-08-2017, 01:23 PM
RE: Non-Philco general question - by Radioroslyn - 11-08-2017, 03:22 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
