Restoring a 46-1226 Code 125
Threads: 48
City: Tioga, Texas, USA
Today I finished replacing the electrolytic sections in both can electrolytic capacitors in the power supply. There were two, a small one P/N 30-2570 which consisted of two sections tied together, a 25uF@450V and a 10uF@450V with a 10K 2W resistor going back to the triangle section a 10uF@450V of the large can, P/N 30-2556, and a Philco Power resistor P/N 33-1336-51 from the small can to the 25uF@450V half-round section of the large can, P/N 30-2556. When I was removing the large can electrolytic I discovered that its ground twist-tabs were never soldered at the factory. Not a single twist tab of the large electrloytic had been soldered to ground. I made sure that one of them was soldered to the chassis this time. It may not have caused a problem, but better safe than sorry.
Next come the replacing of all the paper-wax-foil capacitors in the set. some are in tight spots, but nothing looks too difficult.
Joe
RE: Restoring a 46-1226 Code 125 - by Joeztech - 11-09-2017, 12:58 PM
Users browsing this thread: 30 Guest(s)
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
Hello mike,
What nice looking radio I have one AK in my collection it's a console I have not started restoring it yet ....radiorich — 11:21 PM |
91H Code 126 Restore
Just to make it more confusing here is another model 91 schematic that doesn't show parts with dotted lines in that spot...Arran — 10:37 PM |
The wires were desoldered from the can, and the capacitors checked. All checked at 0.102 uF, which is correct.
So the c...morzh — 09:41 PM |
Yours probably then the H speaker, same as mine.morzh — 08:39 PM |
Mike;
I would like to have a look at the speaker in my model 96, but the set is packed into a corner in the basement. ...Arran — 08:04 PM |
Thanks Arran,
I'm convinced the power cord is good but have a nice repro plug for it. Would it be prudent to add a fus...RealRider — 07:28 PM |
As I was studying this schematic I was wondering what does this dotted line means? I haven't traced it out yet.
An o...RealRider — 07:22 PM |
There are currently 3978 online users. [Complete List] » 3 Member(s) | 3975 Guest(s)
