Chassis vernier removal question
Sorry, yes for the 37-675.
I figured out that I did not need to remove it. I tried a little sewing machine oil and it loosened the vernier shaft up really nicely.
Chassis vernier removal question - by xwarp - 11-09-2017, 11:01 PM
RE: Chassis vernier removal question - by w4rtc - 11-09-2017, 11:24 PM
RE: Chassis vernier removal question - by xwarp - 11-09-2017, 11:46 PM
RE: Chassis vernier removal question - by xwarp - 11-09-2017, 11:50 PM
RE: Chassis vernier removal question - by Arran - 11-10-2017, 05:00 AM
RE: Chassis vernier removal question - by 462ron - 11-10-2017, 08:46 AM
RE: Chassis vernier removal question - by xwarp - 11-10-2017, 02:02 PM
The speaker table error?
Philco 70 antenna lead
