1930 mod.96
Welcome!
Look inside your radio and carefully count the number of tubes. It may or may not have the large tube shield in back which can easily be removed by loosening some screws on the very back of the chassis and then sliding it up and out of the way.
9 tubes - Model 96
7 tubes - Model 77
It is probably one of the two above.
A Model 30 will have 8 tubes but no AC cord since the 30 was battery operated.
A Model 41 will have 6 tubes and a large ballast resistor mounted somewhere inside the cabinet. It will also have what looks like an AC cord but don't try to plug it in because the 41 is a DC-only set!
The 96 and 77 run on AC only, both have large power transformers which the 30 and 41 will not have.
1930 mod.96 - by Guest - 03-28-2010, 07:22 AM
Re: 1930 mod.96 - by Ron Ramirez - 03-28-2010, 08:19 AM
Re: 1930 mod.96 - by Guest - 03-28-2010, 08:48 AM
Re: 1930 mod.96 - by 7estatdef - 03-30-2010, 10:00 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 9466 online users. [Complete List]
» 2 Member(s) | 9464 Guest(s)
