Philco 118x floor model restoration
ok cool. ive got a pile of 1/2 watt resistors, but only a few 1k and 10k 1 watt and 2 watt resistors. are there any resistors that should specifically be over 1/2 watt?
thanks again, you guys rule.
Brian
Philco 118x floor model restoration - by Foose - 11-05-2017, 04:02 PM
RE: Philco 118x floor model restoration - by Foose - 11-17-2017, 07:05 PM
The speaker table error?
Philco 70 antenna lead
