Ship radio Woes
The other tube is a 12z3.  I was  told that it needs a ballast instead of that tube. The ballast number is L55CG. I am not in front of the radio and am away right now but I will check the continuity when I get home.
Ship radio Woes - by OldRestorer - 11-15-2017, 09:06 PM
RE: Ship radio Woes - by OldRestorer - 11-15-2017, 09:08 PM
RE: Ship radio Woes - by Radioroslyn - 11-15-2017, 11:19 PM
RE: Ship radio Woes - by Arran - 11-16-2017, 02:41 AM
RE: Ship radio Woes - by jcassity - 11-17-2017, 06:51 AM
RE: Ship radio Woes - by OldRestorer - 11-18-2017, 03:08 PM
RE: Ship radio Woes - by OldRestorer - 11-18-2017, 11:36 PM
RE: Ship radio Woes - by Arran - 11-19-2017, 01:18 AM
RE: Ship radio Woes - by Paul Philco322 - 11-19-2017, 08:08 PM
RE: Ship radio Woes - by OldRestorer - 11-20-2017, 03:49 AM
RE: Ship radio Woes - by Radioroslyn - 09-26-2018, 11:10 PM
RE: Ship radio Woes - by Eliot Ness - 09-27-2018, 07:56 AM
There are currently 9796 online users. [Complete List]
» 3 Member(s) | 9793 Guest(s)
