48-200 code121 Filament Wiring incorrect
Well, 50A5 and 50L6 are the same tube with different bases: the former is loctal and the other is octal. The sch calls for the latter and you have the former, hence the confusion.
I don't know if there was a version that used 50A5, some radios were like that, but see what you have first.
RE: 48-200 code121 Filament Wiring incorrect - by morzh - 11-18-2017, 05:52 PM
The speaker table error?
Philco 70 antenna lead
