FM Dial won't line up
L-3 (fm osc coil) has a bit too much inductance. If you can stretch it out bit will lower it's inductance. Once you get the low end close then use the trimmer to set the high end. On a lot of these sets it's tough to get them dead on across the whole band but should be much better than what you've got.
FM Dial won't line up - by Eric Adams - 11-05-2017, 05:50 PM
RE: FM Dial won't line up - by Paul Philco322 - 11-19-2017, 10:06 AM
RE: FM Dial won't line up - by Radioroslyn - 11-19-2017, 12:05 PM
RE: FM Dial won't line up - by jcassity - 11-19-2017, 01:19 PM
RE: FM Dial won't line up - by Jayce - 11-19-2017, 04:48 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
