48-200 code121 Filament Wiring incorrect
Terry, thanks for your reply.  I probably did apply AC to the cap(s).  I converted the single three way cap to three new smaller cans.  I'll check them and replace as necessary.  I did a messy job anyway with all the leads being bare.  When I was checking voltages the tip of my meter lead did touch one of the + cap wires while I was checking the filament voltage and the pilot light came on several times before it blew.
Welder
RE: 48-200 code121 Filament Wiring incorrect - by Welder - 11-20-2017, 05:05 AM
The speaker table error?
Philco 70 antenna lead
