48-200 code121 Filament Wiring incorrect
Terry:  I was hoping I'd get a response like yours.  My sch. shows the 35Y4 and I'm having trouble following the pins 'cause it's a 35Z5.  I've been moving things around and got the pilot light working w/o burning it out but now resistor R102 (1200 ohms) is cooking when I crank it up to 110V.  I can't seem to find the right pin for the pos leg of one of the 33 uf caps ergo the burning resistor. I'll check resistance again.
Rich
RE: 48-200 code121 Filament Wiring incorrect - by Welder - 11-21-2017, 01:20 PM
The speaker table error?
Philco 70 antenna lead
