Canadian made Philco Model 730
Thanks for the advice Icon_biggrin . I think a similar model is the 51-1731 but it is listed as BC and FM. The one I have is only BC probably because there were not many FM stations in Canada at that time. I downloaded the schematics for the 51-1731 and does not seem to match what I have in my unit although the record player matches. I'll try http://www.justradios.com/ . They may have schematics for this unit.
Thanks again Icon_smile
Canadian made Philco Model 730 - by Guest - 01-24-2006, 09:44 PM
[No subject] - by Guest - 01-24-2006, 09:51 PM
[No subject] - by 49Stude63 - 01-25-2006, 12:05 AM
[No subject] - by Guest - 01-25-2006, 05:47 PM
[No subject] - by Guest - 12-03-2007, 11:18 PM
[No subject] - by Carl Travis - 12-04-2007, 09:06 AM
Philco 91 Tuning Condenser
