48-200 code121 Filament Wiring incorrect
> I understand everything
Geez your doing a lot better than me!!!!
RE: 48-200 code121 Filament Wiring incorrect - by Radioroslyn - 11-22-2017, 03:39 PM
The speaker table error?
Philco 70 antenna lead
