Crosley 124
ALL< UPDATE: I was able to repair the Field Coil.. I found the 2 ends and was able to solder to them..
So now the field coil is repaired.. Reading 648 Ohms... Now on to the installation of the replacement antenna coil.. and finish up the wiring...
Thanks all to suggestions on how to fix that coil They helped a lot..
Skip...
Crosley 124 - by vecher - 10-25-2017, 08:45 PM
RE: Crosley 124 - by Phlogiston - 10-25-2017, 09:30 PM
RE: Crosley 124 - by vecher - 10-25-2017, 11:37 PM
RE: Crosley 124 - by Phlogiston - 10-26-2017, 11:17 AM
RE: Crosley 124 - by vecher - 10-26-2017, 08:57 PM
RE: Crosley 124 - by Phlogiston - 10-27-2017, 10:56 AM
RE: Crosley 124 - by vecher - 10-27-2017, 10:31 PM
RE: Crosley 124 - by vecher - 10-28-2017, 03:57 PM
RE: Crosley 124 - by Radioroslyn - 10-28-2017, 05:29 PM
RE: Crosley 124 - by vecher - 10-28-2017, 07:23 PM
RE: Crosley 124 - by Radioroslyn - 10-28-2017, 07:28 PM
RE: Crosley 124 - by vecher - 10-28-2017, 09:25 PM
RE: Crosley 124 - by vecher - 10-31-2017, 11:41 AM
RE: Crosley 124 - by Radioroslyn - 10-31-2017, 05:10 PM
RE: Crosley 124 - by Eliot Ness - 11-01-2017, 08:25 AM
RE: Crosley 124 - by vecher - 11-04-2017, 09:31 PM
RE: Crosley 124 - by Arran - 11-04-2017, 11:23 PM
RE: Crosley 124 - by vecher - 11-05-2017, 02:58 PM
RE: Crosley 124 - by vecher - 11-19-2017, 11:41 PM
RE: Crosley 124 - by vinzer - 11-21-2017, 12:16 PM
RE: Crosley 124 - by Phlogiston - 11-21-2017, 02:05 PM
RE: Crosley 124 - by Phlogiston - 11-21-2017, 02:11 PM
RE: Crosley 124 - by vecher - 11-21-2017, 08:02 PM
RE: Crosley 124 - by vecher - 11-21-2017, 10:39 PM
RE: Crosley 124 - by Arran - 11-22-2017, 12:59 AM
RE: Crosley 124 - by vecher - 11-22-2017, 01:21 AM
RE: Crosley 124 - by Phlogiston - 11-22-2017, 12:49 PM
RE: Crosley 124 - by vinzer - 11-22-2017, 10:03 PM
RE: Crosley 124 - by vecher - 11-22-2017, 10:20 PM
RE: Crosley 124 - by klondike98 - 11-22-2017, 11:11 PM
RE: Crosley 124 - by Eliot Ness - 11-23-2017, 11:22 AM
RE: Crosley 124 - by vecher - 11-24-2017, 06:19 PM
RE: Crosley 124 - by Phlogiston - 11-25-2017, 12:53 PM
RE: Crosley 124 - by vecher - 11-25-2017, 03:02 PM
RE: Crosley 124 - by Phlogiston - 11-25-2017, 05:13 PM
RE: Crosley 124 - by vecher - 11-25-2017, 10:45 PM
RE: Crosley 124 - by vecher - 12-13-2017, 02:14 PM
RE: Crosley 124 - by vecher - 12-13-2017, 07:44 PM
RE: Crosley 124 - by vecher - 03-08-2018, 08:48 PM
RE: Crosley 124 - by Radioroslyn - 03-08-2018, 11:37 PM
RE: Crosley 124 - by Arran - 03-09-2018, 03:34 AM
RE: Crosley 124 - by Eliot Ness - 03-09-2018, 08:31 AM
RE: Crosley 124 - by vecher - 03-18-2018, 10:40 AM
RE: Crosley 124 - by vecher - 03-18-2018, 10:57 AM
RE: Crosley 124 - by KCMike - 03-18-2018, 12:46 PM
RE: Crosley 124 - by vecher - 03-18-2018, 03:12 PM
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
