46-1201 code 121
Thanks for the info.  The mercury switch seems to be working.  It does look like this unit has been used much.  The rubber on the wheel seems to have some life in it. The speed seems to be correct in that the sound from the record is not distorted.
46-1201 code 121 - by Jim421 - 11-10-2017, 02:26 PM
RE: 46-1201 code 121 - by klondike98 - 11-10-2017, 02:56 PM
RE: 46-1201 code 121 - by Jim421 - 11-10-2017, 06:43 PM
RE: 46-1201 code 121 - by davidff - 11-20-2017, 04:15 PM
RE: 46-1201 code 121 - by NostalgiaRadioTime - 11-20-2017, 07:49 PM
RE: 46-1201 code 121 - by Jim421 - 11-24-2017, 02:56 PM
RE: 46-1201 code 121 - by Jim421 - 11-24-2017, 02:59 PM
The speaker table error?
Philco 70 antenna lead
