38-1 code 121A
>. YES?
Yes.
> correctly, as the positive leg appears to be going to ground...
Yes.
>Is this chassis ground
Yes.
> the positive of the 10uf (#102) was grounded there?
Don't know, doesn't matter as long as it's at chassis ground.
38-1 code 121A - by Electrothaumaturgist - 09-28-2017, 01:37 AM
RE: 38-1 code 121A - by Radioroslyn - 09-28-2017, 03:29 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 09-28-2017, 04:01 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 10-28-2017, 03:39 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 10-28-2017, 03:51 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 10-28-2017, 04:13 PM
RE: 38-1 code 121A - by morzh - 10-28-2017, 05:04 PM
RE: 38-1 code 121A - by Radioroslyn - 10-28-2017, 05:12 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 10-28-2017, 06:16 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-08-2017, 01:33 AM
RE: 38-1 code 121A - by Radioroslyn - 11-08-2017, 12:50 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-08-2017, 11:05 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-08-2017, 11:10 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-08-2017, 11:18 PM
RE: 38-1 code 121A - by Radioroslyn - 11-08-2017, 11:25 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-08-2017, 11:35 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-08-2017, 11:38 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-11-2017, 05:33 AM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-18-2017, 03:21 AM
RE: 38-1 code 121A - by Ron Ramirez - 11-18-2017, 09:05 AM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-18-2017, 11:17 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-25-2017, 12:45 AM
RE: 38-1 code 121A - by Radioroslyn - 11-25-2017, 11:42 AM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-25-2017, 04:35 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-28-2017, 03:02 AM
RE: 38-1 code 121A - by Radioroslyn - 11-28-2017, 01:27 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-28-2017, 01:31 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-28-2017, 01:44 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-28-2017, 02:03 PM
RE: 38-1 code 121A - by Radioroslyn - 11-28-2017, 02:47 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-28-2017, 08:33 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-29-2017, 11:13 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-03-2017, 07:55 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-04-2017, 05:53 PM
RE: 38-1 code 121A - by Radioroslyn - 12-04-2017, 07:38 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-04-2017, 08:35 PM
RE: 38-1 code 121A - by Radioroslyn - 12-04-2017, 08:52 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-04-2017, 10:13 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-16-2017, 01:20 AM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-16-2017, 06:48 AM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-25-2017, 04:42 PM
RE: 38-1 code 121A - by EdHolland - 12-26-2017, 10:45 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-27-2017, 07:16 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6944 online users. [Complete List]
» 2 Member(s) | 6942 Guest(s)
