Model 14 Sensitivity
When you remove the grid cap from the RF tube, does putiing your finger on the cap restore reception? The grid wire itself is an antenna. The Rf Section and n your case might be working, but what you have told so far does not prove it.
Only successful putting the signal through the antenna connector proves it.
Model 14 Sensitivity - by rfeenstra - 11-25-2017, 01:34 PM
RE: Model 14 Sensitivity - by morzh - 11-25-2017, 02:10 PM
RE: Model 14 Sensitivity - by rfeenstra - 11-25-2017, 03:38 PM
RE: Model 14 Sensitivity - by morzh - 11-25-2017, 04:24 PM
RE: Model 14 Sensitivity - by rfeenstra - 11-25-2017, 06:47 PM
RE: Model 14 Sensitivity - by morzh - 11-25-2017, 09:14 PM
RE: Model 14 Sensitivity - by rfeenstra - 11-25-2017, 09:53 PM
RE: Model 14 Sensitivity - by Steve Davis - 11-26-2017, 12:11 AM
RE: Model 14 Sensitivity - by rfeenstra - 11-26-2017, 01:37 AM
The speaker table error?
Philco 70 antenna lead
