42-380 Restoration Started
Russ, Chuck Schwark here on the Phorum has a schematic service. He should have the info on your set and his prices are VERY reasonable. When I ordered he also included my schematic on an 11 x 17 page--much nicer to look at. Icon_smile
42-380 Restoration Started - by rkeller - 03-28-2010, 06:38 PM
Re: 42-380 Restoration Started - by dberman51 - 03-28-2010, 08:09 PM
Re: 42-380 Restoration Started - by DeckApe - 03-30-2010, 09:27 AM
Re: 42-380 Restoration Started - by rkeller - 04-10-2010, 07:46 AM
Re: 42-380 Restoration Started - by codefox1 - 04-10-2010, 10:39 AM
Re: 42-380 Restoration Started - by rkeller - 04-14-2010, 07:40 PM
Re: 42-380 Restoration Started - by Ron Ramirez - 04-14-2010, 08:50 PM
Re: 42-380 Restoration Started - by rkeller - 04-17-2010, 12:36 PM
Re: 42-380 Restoration Started - by DeckApe - 04-20-2010, 05:04 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
