40-180 Voltage High
That is correct. The 7A7 was in the radio when I got it 50 years ago. I read in some cases it can be used as a substitute so I didn't suspect it was a problem since it worked for so long but everything should be suspect now. I discovered one of the e-caps had been replaced before I got it and stuck under the deck so the tube was probably replaced back then.
<!-- m --><a class="postlink" href="http://frank.pocnet.net/sheets/084/7/7B7.pdf">http://frank.pocnet.net/sheets/084/7/7B7.pdf</a><!-- m -->
<!-- m --><a class="postlink" href="http://frank.pocnet.net/sheets/084/7/7A7.pdf">http://frank.pocnet.net/sheets/084/7/7A7.pdf</a><!-- m -->
40-180 Voltage High - by Bruce C - 03-29-2010, 05:20 PM
Re: 40-180 Voltage High - by DeckApe - 03-30-2010, 09:36 AM
Re: 40-180 Voltage High - by Bruce C - 03-30-2010, 10:48 AM
Re: 40-180 Voltage High - by rghines1 - 03-30-2010, 05:48 PM
Re: 40-180 Voltage High - by Bruce C - 03-30-2010, 07:18 PM
Re: 40-180 Voltage High - by rghines1 - 03-31-2010, 04:58 PM
Re: 40-180 Voltage High - by Bruce C - 03-31-2010, 10:32 PM
Re: 40-180 Voltage High - by Bruce C - 04-04-2010, 07:16 PM
Re: 40-180 Voltage High - by rghines1 - 04-05-2010, 08:47 AM
Re: 40-180 Voltage High - by Bruce C - 04-05-2010, 07:34 PM
Re: 40-180 Voltage High - by exray - 04-05-2010, 10:40 PM
Re: 40-180 Voltage High - by Raleigh - 04-05-2010, 10:59 PM
Re: 40-180 Voltage High - by exray - 04-05-2010, 11:26 PM
Re: 40-180 Voltage High - by codefox1 - 04-06-2010, 02:12 PM
Re: 40-180 Voltage High - by Bruce C - 04-06-2010, 05:08 PM
Re: 40-180 Voltage High - by Bruce C - 04-20-2010, 05:47 PM
Re: 40-180 Voltage High - by Bruce C - 04-26-2010, 05:36 PM
Re: 40-180 Voltage High - by Ron Ramirez - 04-26-2010, 05:51 PM
Re: 40-180 Voltage High - by denver - 04-26-2010, 07:28 PM
Re: 40-180 Voltage High - by Bruce C - 04-30-2010, 01:35 PM
Re: 40-180 Voltage High - by exray - 05-01-2010, 02:36 AM
Re: 40-180 Voltage High - by Bruce C - 05-07-2010, 11:03 AM
Re: 40-180 Voltage High - by codefox1 - 05-08-2010, 10:45 AM
Re: 40-180 Voltage High - by Raleigh - 05-12-2010, 02:09 PM
Re: 40-180 Voltage High - by Bruce C - 05-12-2010, 08:06 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
