  • 1 Vote(s) - 2 Average
Restoring a 46-1226 Code 125
#33
jcassity;
OK, thanks for that item. I will check mine to see what is happening with the dial string and levers.
This morning I did do a check of all the tubes. All checked OK except for the 6J5, which in this set was a metal tube. The 6J5 had no emission whatsoever! The tube did get warm, but just no emission. I had another 6J5 that checked good from an E H Scott 800B tuner parts chassis. I installed that tube so that the audio section would have some chance to work.
Now for the checks on the power transformer, 5Y3, 300 ohm resistor in the B+ and the AC measurements:
AC input voltage this morning was 123VAC.
Measuring at pin 4 and 6 of the 5Y3 socket, tube removed, 705VAC
Measuring ground to pin 4 of 5Y3 socket, tube removed, 352VAC
Measuring ground to pin 6 of 5Y3 socket, tube removed, 352VAC
Measuring pin 4 to 6 of the 5Y3 socket, tube installed, 690VAC
Measuring Gnd to pin 4 of the 5Y3 socket, tube installed, 345VAC
Measuring Gnd to pin 6 of the 5Y3 socket, tube installed, 345VAC
Measuring at 5Y3 cathode, tube installed, 31VAC and +337VDC
Measuring at the first Electrolytic filter section, +311VDC
The 300 ohm resistor is hot but not smoking and although I would not want to keep my finger on it, it is well within the capability of the 5W resistor I installed.
My next step will be to try the chassis with a speaker and an antenna to see if I can pick up any stations.
Here are a couple of pictures of the chassis;
Joe
Restoring a 46-1226 Code 125 - by Joeztech - 10-28-2017, 05:28 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 10-29-2017, 08:27 PM
RE: Restoring a 46-1226 Code 125 - by Ron Ramirez - 10-29-2017, 09:00 PM
RE: Restoring a 46-1226 Code 125 - by morzh - 10-29-2017, 09:37 PM
RE: Restoring a 46-1226 Code 125 - by Ron Ramirez - 10-30-2017, 06:03 AM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 10-30-2017, 07:13 AM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 10-30-2017, 07:51 PM
RE: Restoring a 46-1226 Code 125 - by Ron Ramirez - 10-30-2017, 09:51 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 10-31-2017, 06:40 AM
RE: Restoring a 46-1226 Code 125 - by Ron Ramirez - 10-31-2017, 12:45 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 10-31-2017, 02:23 PM
RE: Restoring a 46-1226 Code 125 - by jcassity - 11-05-2017, 12:34 AM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 11-05-2017, 07:52 AM
RE: Restoring a 46-1226 Code 125 - by jcassity - 11-05-2017, 10:48 AM
RE: Restoring a 46-1226 Code 125 - by jcassity - 11-05-2017, 12:13 PM
RE: Restoring a 46-1226 Code 125 - by jcassity - 11-06-2017, 09:40 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 11-09-2017, 12:58 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 11-09-2017, 07:03 PM
RE: Restoring a 46-1226 Code 125 - by morzh - 11-09-2017, 07:30 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 11-10-2017, 01:34 PM
RE: Restoring a 46-1226 Code 125 - by Radioroslyn - 11-10-2017, 03:16 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 11-10-2017, 03:37 PM
RE: Restoring a 46-1226 Code 125 - by Radioroslyn - 11-10-2017, 05:27 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 11-10-2017, 08:59 PM
RE: Restoring a 46-1226 Code 125 - by jcassity - 11-12-2017, 08:33 AM
RE: Restoring a 46-1226 Code 125 - by jcassity - 11-12-2017, 09:17 AM
RE: Restoring a 46-1226 Code 125 - by jcassity - 11-12-2017, 10:01 AM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 11-12-2017, 01:43 PM
RE: Restoring a 46-1226 Code 125 - by jcassity - 11-12-2017, 03:06 PM
RE: Restoring a 46-1226 Code 125 - by jcassity - 11-22-2017, 09:54 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 11-26-2017, 08:36 PM
RE: Restoring a 46-1226 Code 125 - by jcassity - 11-27-2017, 09:35 AM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 11-27-2017, 12:01 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 11-27-2017, 12:24 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 11-27-2017, 02:02 PM
RE: Restoring a 46-1226 Code 125 - by jcassity - 11-27-2017, 04:17 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 11-27-2017, 05:21 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 11-28-2017, 08:34 AM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 11-28-2017, 05:16 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 12-05-2017, 01:51 PM
RE: Restoring a 46-1226 Code 125 - by jcassity - 12-06-2017, 08:25 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 12-06-2017, 09:03 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 12-26-2017, 12:00 PM
RE: Restoring a 46-1226 Code 125 - by Radioroslyn - 12-26-2017, 12:16 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 12-26-2017, 05:23 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 12-27-2017, 06:07 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 12-31-2017, 06:27 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 01-06-2018, 03:38 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 01-08-2018, 01:34 PM
RE: Restoring a 46-1226 Code 125 - by jcassity - 01-09-2018, 11:13 AM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 01-09-2018, 02:35 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 01-11-2018, 09:36 AM
RE: Restoring a 46-1226 Code 125 - by jcassity - 01-11-2018, 12:59 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 01-12-2018, 12:33 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 01-12-2018, 01:44 PM
RE: Restoring a 46-1226 Code 125 - by Ron Ramirez - 01-12-2018, 01:45 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 01-13-2018, 12:31 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 01-20-2018, 08:38 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 01-22-2018, 03:08 PM
RE: Restoring a 46-1226 Code 125 - by Ron Ramirez - 01-22-2018, 03:45 PM
RE: Restoring a 46-1226 Code 125 - by morzh - 01-22-2018, 04:04 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 01-22-2018, 04:06 PM
RE: Restoring a 46-1226 Code 125 - by Ron Ramirez - 01-22-2018, 04:22 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 01-22-2018, 05:34 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 01-22-2018, 05:52 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 01-22-2018, 06:34 PM
RE: Restoring a 46-1226 Code 125 - by Ron Ramirez - 01-22-2018, 10:53 PM
RE: Restoring a 46-1226 Code 125 - by Arran - 01-23-2018, 01:31 AM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 01-23-2018, 08:15 AM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 01-23-2018, 04:29 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 01-28-2018, 03:35 PM
RE: Restoring a 46-1226 Code 125 - by jcassity - 01-30-2018, 07:52 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 01-31-2018, 08:26 AM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 02-04-2018, 02:55 PM
RE: Restoring a 46-1226 Code 125 - by jcassity - 02-06-2018, 01:55 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 02-06-2018, 03:51 PM
RE: Restoring a 46-1226 Code 125 - by jcassity - 02-06-2018, 09:42 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 02-25-2018, 03:46 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 02-27-2018, 12:03 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 03-03-2018, 12:19 PM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 03-17-2018, 07:28 PM
RE: Restoring a 46-1226 Code 125 - by Arran - 03-18-2018, 02:10 AM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 03-18-2018, 06:55 AM
RE: Restoring a 46-1226 Code 125 - by 462ron - 03-18-2018, 10:17 AM
RE: Restoring a 46-1226 Code 125 - by Joeztech - 03-18-2018, 01:10 PM
RE: Restoring a 46-1226 Code 125 - by jcassity - 02-10-2019, 08:05 PM
RE: Restoring a 46-1226 Code 125 - by jcassity - 02-10-2019, 08:09 PM
RE: Restoring a 46-1226 Code 125 - by jcassity - 02-10-2019, 08:20 PM
RE: Restoring a 46-1226 Code 125 - by DavidHTO - 02-10-2019, 09:51 PM
RE: Restoring a 46-1226 Code 125 - by jcassity - 02-11-2019, 08:20 AM
RE: Restoring a 46-1226 Code 125 - by DavidHTO - 02-11-2019, 08:57 AM
91H Code 126 Restore
There are currently 3042 online users. [Complete List]
» 1 Member(s) | 3041 Guest(s)
