Cabinet colors???
I have a 40-190 that needs refinished and need some help with toned lacquer color selection. The lacquer on the solid (non-veneered) sections is slightly opaque. Does anyone know what Mohawk lacquers to use? Has anyone ever put together a color chart for old radios? Thanks
Cabinet colors??? - by baspas - 03-30-2010, 06:17 PM
Re: Cabinet colors??? - by Ron Ramirez - 04-02-2010, 09:06 AM
Re: Cabinet colors??? - by exray - 04-02-2010, 07:51 PM
There are currently 10388 online users. [Complete List]
» 2 Member(s) | 10386 Guest(s)
