Restoring a 46-1226 Code 125
Threads: 48
City: Tioga, Texas, USA
I found the break in the wire of the antenna transformer by connecting one lead of the ohmmeter to the center tap lug on the bottom of the coil form, then using the other meter lead to move along the circumference of the top winding. I could hit a certain spot and establish continuity. I began to work on that spot with my finger nail and also a scribe and eventually managed to break away some of the original glue that held the end of the winding to the rest of that coil section. I wound up with about 3/8" of lead to work with. I used a small white wire from very small shielded audio cable to make the connection to the end of the exposed wire after first tinning the end until the litz wire insulation was burned back enough to tin about 1/16" of the wire. The other end of the wire was attached to the solder lug on the coil form that the white wire from under the chassis was attached to and soldered. I used some magic mending tape to secure the new white wire to the coil form body and then shrunk the white heat-shrink tubing I had slid over the small white wire. Next some clear plastic glue was used to stabilize the soldered wire to wire end at the coil. Here is a picture of the repaired coil.
Joe
RE: Restoring a 46-1226 Code 125 - by Joeztech - 11-28-2017, 08:34 AM
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
Hello mike,
What nice looking radio I have one AK in my collection it's a console I have not started restoring it yet ....radiorich — 11:21 PM |
91H Code 126 Restore
Just to make it more confusing here is another model 91 schematic that doesn't show parts with dotted lines in that spot...Arran — 10:37 PM |
The wires were desoldered from the can, and the capacitors checked. All checked at 0.102 uF, which is correct.
So the c...morzh — 09:41 PM |
Yours probably then the H speaker, same as mine.morzh — 08:39 PM |
Mike;
I would like to have a look at the speaker in my model 96, but the set is packed into a corner in the basement. ...Arran — 08:04 PM |
Thanks Arran,
I'm convinced the power cord is good but have a nice repro plug for it. Would it be prudent to add a fus...RealRider — 07:28 PM |
As I was studying this schematic I was wondering what does this dotted line means? I haven't traced it out yet.
An o...RealRider — 07:22 PM |
There are currently 3037 online users. [Complete List] » 1 Member(s) | 3036 Guest(s)
