Model 96 Restoration
Awesome! Thanks.  I was able to unwind the resistor wire from the terminal so I didn't need to get more wire out.  Didn't realize it would have been so simple.  This is a great forum (phorum)!
Model 96 Restoration - by rfeenstra - 11-28-2017, 07:44 PM
RE: Model 96 Restoration - by klondike98 - 11-28-2017, 07:55 PM
RE: Model 96 Restoration - by rfeenstra - 11-28-2017, 08:16 PM
RE: Model 96 Restoration - by morzh - 11-28-2017, 11:37 PM
RE: Model 96 Restoration - by rfeenstra - 11-29-2017, 02:17 AM
RE: Model 96 Restoration - by Arran - 11-29-2017, 04:40 AM
RE: Model 96 Restoration - by rfeenstra - 11-29-2017, 11:02 AM
RE: Model 96 Restoration - by rfeenstra - 11-29-2017, 09:24 PM
RE: Model 96 Restoration - by rfeenstra - 11-30-2017, 03:55 AM
RE: Model 96 Restoration - by morzh - 11-30-2017, 11:17 AM
RE: Model 96 Restoration - by Ron Ramirez - 11-30-2017, 06:45 PM
RE: Model 96 Restoration - by rfeenstra - 11-30-2017, 08:09 PM
RE: Model 96 Restoration - by rfeenstra - 12-03-2017, 02:41 AM
RE: Model 96 Restoration - by rfeenstra - 12-03-2017, 02:52 AM
RE: Model 96 Restoration - by rfeenstra - 12-03-2017, 08:31 PM
RE: Model 96 Restoration - by rfeenstra - 12-03-2017, 08:59 PM
RE: Model 96 Restoration - by rfeenstra - 12-04-2017, 12:49 AM
RE: Model 96 Restoration - by Arran - 12-04-2017, 12:59 AM
RE: Model 96 Restoration - by rfeenstra - 12-04-2017, 01:23 AM
RE: Model 96 Restoration - by rfeenstra - 12-12-2017, 01:07 AM
RE: Model 96 Restoration - by rfeenstra - 12-12-2017, 11:50 PM
RE: Model 96 Restoration - by morzh - 12-13-2017, 12:37 AM
RE: Model 96 Restoration - by rfeenstra - 12-13-2017, 09:11 AM
RE: Model 96 Restoration - by morzh - 12-13-2017, 09:21 AM
RE: Model 96 Restoration - by rfeenstra - 12-13-2017, 10:49 AM
The speaker table error?
Philco 70 antenna lead
