Beverage antenna
..antennas (editing on this phone is tricky) efficiency is less important than S/N.
Good discussion!
Beverage antenna - by jcassity - 11-28-2017, 04:40 PM
RE: Beverage antenna - by EdHolland - 11-28-2017, 05:05 PM
RE: Beverage antenna - by Paul Philco322 - 11-28-2017, 09:29 PM
RE: Beverage antenna - by jcassity - 11-29-2017, 10:47 AM
RE: Beverage antenna - by EdHolland - 11-29-2017, 11:42 AM
RE: Beverage antenna - by EdHolland - 11-29-2017, 11:43 AM
RE: Beverage antenna - by jcassity - 11-29-2017, 02:15 PM
RE: Beverage antenna - by jcassity - 11-29-2017, 02:17 PM
RE: Beverage antenna - by EdHolland - 11-29-2017, 02:53 PM
RE: Beverage antenna - by David - 11-29-2017, 08:31 PM
RE: Beverage antenna - by jcassity - 11-30-2017, 12:03 PM
RE: Beverage antenna - by EdHolland - 11-30-2017, 01:28 PM
RE: Beverage antenna - by jcassity - 11-30-2017, 05:52 PM
RE: Beverage antenna - by EdHolland - 11-30-2017, 06:11 PM
RE: Beverage antenna - by Paul Philco322 - 11-30-2017, 09:43 PM
RE: Beverage antenna - by Kenneth F. Besso Jr. - 12-01-2017, 06:18 PM
The speaker table error?
Philco 70 antenna lead
