Philco Model 256F UK Model ?
Hi Dave and welcome,
The chassis does look a lot like the US model 50 BUT your set is a superhet where as the 50 is the old trf design. More than likely it's closer to the model 52. The output tube in the rear view of your set looks a bit small to be a #47 tube. Looks more like a 2A5 (2.5v heater) or the newer 42 (6.3v heater). Don't know if there is a corresponding US model. Here's the data on the 52:  http://www.nostalgiaair.org/pagesbymodel...029635.pdf
My best guess on the Gramophone is that it's a UK built devise, again may not be anything over here that looks like it.
Perhaps others may have some more encouraging news.
Philco Model 256F UK Model ? - by Radiomad1 - 11-29-2017, 10:42 AM
RE: Philco Model 256F UK Model ? - by morzh - 11-29-2017, 12:13 PM
RE: Philco Model 256F UK Model ? - by Radiomad1 - 11-29-2017, 12:50 PM
RE: Philco Model 256F UK Model ? - by Radiomad1 - 11-29-2017, 01:06 PM
RE: Philco Model 256F UK Model ? - by Radioroslyn - 11-29-2017, 01:08 PM
RE: Philco Model 256F UK Model ? - by Ron Ramirez - 11-29-2017, 07:29 PM
RE: Philco Model 256F UK Model ? - by Radiomad1 - 11-30-2017, 06:45 AM
RE: Philco Model 256F UK Model ? - by Ron Ramirez - 12-01-2017, 07:21 PM
RE: Philco Model 256F UK Model ? - by Radiomad1 - 12-21-2017, 09:08 AM
RE: Philco Model 256F UK Model ? - by Radiomad1 - 12-21-2017, 10:08 AM
RE: Philco Model 256F UK Model ? - by klondike98 - 12-21-2017, 10:13 AM
RE: Philco Model 256F UK Model ? - by Radiomad1 - 12-21-2017, 12:25 PM
RE: Philco Model 256F UK Model ? - by morzh - 12-21-2017, 01:51 PM
RE: Philco Model 256F UK Model ? - by Ron Ramirez - 12-21-2017, 08:11 PM
RE: Philco Model 256F UK Model ? - by Radiomad1 - 12-22-2017, 05:08 AM
RE: Philco Model 256F UK Model ? - by Arran - 12-26-2017, 04:44 AM
Philco 91 Restore Code ??
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
There are currently 3520 online users. [Complete List]
» 2 Member(s) | 3518 Guest(s)
