A Model 16X story
The original Philco U-2 speaker is 10-1/2 inches in diameter. The eBay cone would be too large, plus the voice coil appears to be 1 inch - too small. And then there's the problem of it having an external spider rather than internal (within the voice coil).
The eBay cone is likely for a 1939-42 (and possibly newer) 12 inch speaker.
A Model 16X story - by EdHolland - 11-26-2017, 09:32 PM
RE: A Model 16X story - by morzh - 11-26-2017, 09:50 PM
RE: A Model 16X story - by VntgRads - 11-27-2017, 02:39 AM
RE: A Model 16X story - by EdHolland - 11-27-2017, 03:16 PM
RE: A Model 16X story - by EdHolland - 11-27-2017, 03:37 PM
RE: A Model 16X story - by EdHolland - 11-27-2017, 06:18 PM
RE: A Model 16X story - by EdHolland - 11-27-2017, 09:15 PM
RE: A Model 16X story - by sam - 11-28-2017, 12:59 PM
RE: A Model 16X story - by EdHolland - 11-28-2017, 01:46 PM
RE: A Model 16X story - by EdHolland - 11-28-2017, 02:04 PM
RE: A Model 16X story - by EdHolland - 11-28-2017, 02:38 PM
RE: A Model 16X story - by morzh - 11-28-2017, 03:08 PM
RE: A Model 16X story - by EdHolland - 11-28-2017, 03:21 PM
RE: A Model 16X story - by morzh - 11-28-2017, 05:49 PM
RE: A Model 16X story - by EdHolland - 11-28-2017, 08:18 PM
RE: A Model 16X story - by EdHolland - 11-29-2017, 01:23 PM
RE: A Model 16X story - by EdHolland - 11-29-2017, 01:29 PM
RE: A Model 16X story - by klondike98 - 11-29-2017, 01:53 PM
RE: A Model 16X story - by morzh - 11-29-2017, 02:13 PM
RE: A Model 16X story - by EdHolland - 11-29-2017, 02:43 PM
RE: A Model 16X story - by morzh - 11-29-2017, 03:40 PM
RE: A Model 16X story - by EdHolland - 11-29-2017, 04:22 PM
RE: A Model 16X story - by morzh - 11-29-2017, 05:14 PM
RE: A Model 16X story - by Ron Ramirez - 11-29-2017, 06:46 PM
RE: A Model 16X story - by EdHolland - 11-29-2017, 07:26 PM
RE: A Model 16X story - by Ron Ramirez - 11-29-2017, 10:28 PM
RE: A Model 16X story - by EdHolland - 11-29-2017, 11:08 PM
RE: A Model 16X story - by Steve Davis - 11-29-2017, 11:17 PM
RE: A Model 16X story - by Electrothaumaturgist - 11-29-2017, 11:26 PM
RE: A Model 16X story - by EdHolland - 12-04-2017, 03:46 PM
RE: A Model 16X story - by EdHolland - 12-08-2017, 03:55 PM
RE: A Model 16X story - by EdHolland - 12-11-2017, 01:39 PM
RE: A Model 16X story - by EdHolland - 12-23-2017, 09:47 PM
RE: A Model 16X story - by EdHolland - 12-26-2017, 10:55 PM
RE: A Model 16X story - by Brad Winder - 12-27-2017, 12:18 AM
RE: A Model 16X story - by Ron Ramirez - 12-27-2017, 12:23 PM
RE: A Model 16X story - by EdHolland - 12-27-2017, 11:46 PM
RE: A Model 16X story - by EdHolland - 12-31-2017, 12:47 PM
RE: A Model 16X story - by EdHolland - 12-31-2017, 05:50 PM
RE: A Model 16X story - by EdHolland - 01-06-2018, 10:29 PM
RE: A Model 16X story - by EdHolland - 01-07-2018, 11:43 PM
RE: A Model 16X story - by EdHolland - 01-11-2018, 01:36 PM
RE: A Model 16X story - by EdHolland - 01-12-2018, 06:13 PM
RE: A Model 16X story - by EdHolland - 01-14-2018, 08:21 PM
RE: A Model 16X story - by morzh - 01-14-2018, 08:53 PM
RE: A Model 16X story - by EdHolland - 01-15-2018, 02:22 PM
RE: A Model 16X story - by morzh - 01-15-2018, 02:26 PM
RE: A Model 16X story - by EdHolland - 01-17-2018, 12:59 PM
RE: A Model 16X story - by EdHolland - 01-19-2018, 07:58 PM
RE: A Model 16X story - by EdHolland - 01-20-2018, 10:46 PM
RE: A Model 16X story - by 462ron - 01-21-2018, 01:47 PM
RE: A Model 16X story - by EdHolland - 01-21-2018, 10:39 PM
RE: A Model 16X story - by 462ron - 01-22-2018, 01:14 AM
RE: A Model 16X story - by EdHolland - 04-02-2018, 02:06 PM
RE: A Model 16X story - by gregb - 04-02-2018, 03:47 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 2275 online users. [Complete List]
» 1 Member(s) | 2274 Guest(s)
