Model 70
Tongue
Ok Here is my latest purchase..
[Image: https://farm5.staticflickr.com/4567/2481...867f_b.jpg]
[Image: https://farm5.staticflickr.com/4576/2481...44c9_b.jpg]
Bottom of chassis really clean..
[Image: https://farm5.staticflickr.com/4580/3865...5239_b.jpg]
OK so now on to some of the problems found..
Bad on off switch.. No big deal
Bad RF coil..  Primary open.. May have a parts set on the way soon to help with this..
Bad Power Transformer.. Open HV Leads.. Well 1/2 of it open. From CTR tap to one end measures around 120 Ohms.. From CTR tap to other Open..
Bad output transformer.. Primary open.. Have a replacement on the way..
The Field coil is good..
The Big resistor under neath is Good..
Osc Coils appears good  Have to do a little more checking on it..
More to follow..  Glad I didn't pay a lot for it....
One Question:  Did other radios use the same Power Transformer?  Just incase the Parts set Transformer is bad....
Skip...
Model 70 - by vecher - 11-29-2017, 09:41 PM
RE: Model 70 - by Ron Ramirez - 11-29-2017, 10:33 PM
RE: Model 70 - by vecher - 12-02-2017, 01:55 AM
RE: Model 70 - by Arran - 12-02-2017, 03:46 AM
RE: Model 70 - by Steve Davis - 12-02-2017, 08:53 AM
RE: Model 70 - by vecher - 12-02-2017, 02:30 PM
RE: Model 70 - by vecher - 12-02-2017, 04:40 PM
RE: Model 70 - by vecher - 12-03-2017, 11:23 AM
RE: Model 70 - by morzh - 12-03-2017, 12:20 PM
RE: Model 70 - by vecher - 12-25-2017, 12:40 AM
RE: Model 70 - by AudreyHepburn - 12-29-2017, 11:14 PM
RE: Model 70 - by vecher - 12-29-2017, 11:59 PM
RE: Model 70 - by Radioroslyn - 12-30-2017, 12:36 AM
RE: Model 70 - by TV MAN - 12-30-2017, 11:30 PM
RE: Model 70 - by vecher - 12-31-2017, 02:19 AM
RE: Model 70 - by vecher - 01-07-2018, 12:17 AM
RE: Model 70 - by klondike98 - 01-07-2018, 09:16 AM
RE: Model 70 - by Steve Davis - 01-07-2018, 10:46 AM
RE: Model 70 - by Ron Ramirez - 01-07-2018, 10:52 AM
RE: Model 70 - by vecher - 01-07-2018, 12:53 PM
RE: Model 70 - by vecher - 01-10-2018, 12:15 PM
RE: Model 70 - by Steve Davis - 01-10-2018, 12:36 PM
RE: Model 70 - by klondike98 - 01-10-2018, 01:07 PM
RE: Model 70 - by vecher - 01-10-2018, 02:08 PM
RE: Model 70 - by morzh - 01-10-2018, 05:05 PM
RE: Model 70 - by klondike98 - 01-10-2018, 06:25 PM
RE: Model 70 - by Warren - 01-10-2018, 09:17 PM
RE: Model 70 - by vecher - 01-11-2018, 12:59 AM
RE: Model 70 - by vecher - 01-11-2018, 01:12 AM
RE: Model 70 - by Steve Davis - 01-11-2018, 02:00 AM
RE: Model 70 - by morzh - 01-11-2018, 09:36 AM
RE: Model 70 - by vecher - 01-13-2018, 08:18 PM
RE: Model 70 - by vecher - 01-13-2018, 08:21 PM
RE: Model 70 - by vecher - 01-17-2018, 12:13 AM
RE: Model 70 - by vecher - 01-20-2018, 09:17 PM
RE: Model 70 - by Steve Davis - 01-21-2018, 12:07 AM
RE: Model 70 - by EdHolland - 01-21-2018, 03:33 AM
RE: Model 70 - by Steve D - 01-21-2018, 11:49 AM
RE: Model 70 - by vecher - 01-21-2018, 02:22 PM
RE: Model 70 - by vecher - 01-21-2018, 06:02 PM
RE: Model 70 - by vecher - 01-22-2018, 12:02 AM
RE: Model 70 - by vecher - 01-22-2018, 09:47 PM
RE: Model 70 - by vecher - 01-28-2018, 11:25 PM
RE: Model 70 - by mg34.42 - 03-18-2018, 03:32 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6176 online users. [Complete List]
» 1 Member(s) | 6175 Guest(s)
