Meissner
Russ;
  I have a Meissner, but it isn't a high end tuner, it's a radio-phonograph-cutter portable. Meissner obviously made the radio chassis and coils, but I think the record player/cutter was made by General Industries. I would like to find a diagram of the cutter as I'm not sure if there are pieces missing.
Meissner - by Phlogiston - 11-28-2017, 01:52 PM
RE: Meissner - by Phlogiston - 11-29-2017, 01:34 PM
RE: Meissner - by Arran - 11-30-2017, 03:40 AM
RE: Meissner - by Ron Ramirez - 11-30-2017, 07:23 AM
RE: Meissner - by Phlogiston - 11-30-2017, 11:50 AM
RE: Meissner - by Arran - 11-30-2017, 11:23 PM
RE: Meissner - by Phlogiston - 12-01-2017, 12:23 PM
RE: Meissner - by Phlogiston - 12-02-2017, 12:48 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
