Meissner
Those Meissners were made by Thordarson-Meissner not too far from here, in Mt. Carmel, Illinois.
Thordarson is still in business but they have moved their headquarters to North Las Vegas, Nevada.
Meissner - by Phlogiston - 11-28-2017, 01:52 PM
RE: Meissner - by Phlogiston - 11-29-2017, 01:34 PM
RE: Meissner - by Arran - 11-30-2017, 03:40 AM
RE: Meissner - by Ron Ramirez - 11-30-2017, 07:23 AM
RE: Meissner - by Phlogiston - 11-30-2017, 11:50 AM
RE: Meissner - by Arran - 11-30-2017, 11:23 PM
RE: Meissner - by Phlogiston - 12-01-2017, 12:23 PM
RE: Meissner - by Phlogiston - 12-02-2017, 12:48 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6841 online users. [Complete List]
» 1 Member(s) | 6840 Guest(s)
