Meissner
You might be right, or at least I thought so prior to seeing some of those ads that seem to show radios with cabinets. I need to do some more research.
This actually comes to the heart of my decision to restore these radios. Like a Scott or McMurdo Silver, it is acceptable to display one of these radios in almost any cabinet - or without one - or with one that displays the radio chassis (Clifton) and consider them to be as sold. And since I have no cabinets, figuring out a Clifton-like display would be my next consideration.
Meissner - by Phlogiston - 11-28-2017, 01:52 PM
RE: Meissner - by Phlogiston - 11-29-2017, 01:34 PM
RE: Meissner - by Arran - 11-30-2017, 03:40 AM
RE: Meissner - by Ron Ramirez - 11-30-2017, 07:23 AM
RE: Meissner - by Phlogiston - 11-30-2017, 11:50 AM
RE: Meissner - by Arran - 11-30-2017, 11:23 PM
RE: Meissner - by Phlogiston - 12-01-2017, 12:23 PM
RE: Meissner - by Phlogiston - 12-02-2017, 12:48 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6753 online users. [Complete List]
» 1 Member(s) | 6752 Guest(s)
