40-180 Voltage High
I hope it is that easy but I am still baffled that I had mostly correct voltages and then with out me doing anything they changed so dramatically. I purchased one each extra of all the caps so I will be doing a lot of rechecking, thanks rghines1.
40-180 Voltage High - by Bruce C - 03-29-2010, 05:20 PM
Re: 40-180 Voltage High - by DeckApe - 03-30-2010, 09:36 AM
Re: 40-180 Voltage High - by Bruce C - 03-30-2010, 10:48 AM
Re: 40-180 Voltage High - by rghines1 - 03-30-2010, 05:48 PM
Re: 40-180 Voltage High - by Bruce C - 03-30-2010, 07:18 PM
Re: 40-180 Voltage High - by rghines1 - 03-31-2010, 04:58 PM
Re: 40-180 Voltage High - by Bruce C - 03-31-2010, 10:32 PM
Re: 40-180 Voltage High - by Bruce C - 04-04-2010, 07:16 PM
Re: 40-180 Voltage High - by rghines1 - 04-05-2010, 08:47 AM
Re: 40-180 Voltage High - by Bruce C - 04-05-2010, 07:34 PM
Re: 40-180 Voltage High - by exray - 04-05-2010, 10:40 PM
Re: 40-180 Voltage High - by Raleigh - 04-05-2010, 10:59 PM
Re: 40-180 Voltage High - by exray - 04-05-2010, 11:26 PM
Re: 40-180 Voltage High - by codefox1 - 04-06-2010, 02:12 PM
Re: 40-180 Voltage High - by Bruce C - 04-06-2010, 05:08 PM
Re: 40-180 Voltage High - by Bruce C - 04-20-2010, 05:47 PM
Re: 40-180 Voltage High - by Bruce C - 04-26-2010, 05:36 PM
Re: 40-180 Voltage High - by Ron Ramirez - 04-26-2010, 05:51 PM
Re: 40-180 Voltage High - by denver - 04-26-2010, 07:28 PM
Re: 40-180 Voltage High - by Bruce C - 04-30-2010, 01:35 PM
Re: 40-180 Voltage High - by exray - 05-01-2010, 02:36 AM
Re: 40-180 Voltage High - by Bruce C - 05-07-2010, 11:03 AM
Re: 40-180 Voltage High - by codefox1 - 05-08-2010, 10:45 AM
Re: 40-180 Voltage High - by Raleigh - 05-12-2010, 02:09 PM
Re: 40-180 Voltage High - by Bruce C - 05-12-2010, 08:06 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
