Attaching Grill Cloth to Cabinet Philco 38-12
I went through that about a year ago.
First, not office staples: you need the wood staples and staplegun. Use 1/4".
Yes they are too long, so put a piece of the same material you use for the frame under the staple before you fire that gun.
http://philcoradio.com/phorum/showthread...587&page=2
This is the thread where I did that. At the end.
RE: Attaching Grill Cloth to Cabinet Philco 38-12 - by morzh - 12-03-2017, 01:30 PM
