Philco 118x floor model restoration
+1 with what Morzh said. Just did a very similar circuit on my 38-1 where the + side of electrolytic goes to ground. You see that every so oft.
Philco 118x floor model restoration - by Foose - 11-05-2017, 04:02 PM
RE: Philco 118x floor model restoration - by Electrothaumaturgist - 12-03-2017, 02:26 PM
The speaker table error?
Philco 70 antenna lead
